TwinTurbo.NET: Nissan 300ZX forum - actually...i've heard the cap holds the lower o-ring on
inf
on January 26, 2013 at 12:15 AM
actually i think the injector needs a new cap (n/m)
posted by inf
on January 26, 2013 at 12:05 AM
does anyone think this is true? I think the o-ring getting squished against the metals is what's holding the fuel and not the little cap...right? That cap can't hold 43 psi worth...
Cylinder 1 and 3 are misfiring...I have Coz's old fuel rail
inf
20:48:16 01/24/13
man, this is so ridiculous..
inf
21:58:44 01/24/13
Maybe you can try swapping spark plugs from a working
Zvil (FL)
22:28:31 01/24/13
hmm...
inf
23:29:02 01/24/13
If it didn't leak when you pressurized it I say your problem
Zvil (FL)
05:32:08 01/25/13
You know how tricky our injectors can be.
TriniTT
11:57:43 01/25/13
check your coil pack connections its possible you
Krazyd27(Houston)
12:49:59 01/25/13
+1 I've had that happen on my old harness (n/m)
Zvil (FL)
16:30:37 01/25/13
I'm not sure how the old harnesses were...probably the same
inf
23:46:25 01/25/13
Ok, so I threw the spark tester in on cyl 1 and it's sparkin
inf
23:44:07 01/25/13
I think I'm just gonna sell this stupid kit...and get a 300
inf
23:47:03 01/25/13
I think the way the adapter kit is designed...due to its
inf
23:49:22 01/25/13
inf
00:05:11 01/26/13
actually...i've heard the cap holds the lower o-ring on -
inf
00:15:26 01/26/13
The cap holds the oring in place once installed.
TriniTT
07:45:21 01/26/13
i installed the injector without the cap and pressurized the
inf
22:48:22 01/28/13
